Help TA4551ci Print Issue
  • lightningazure
    • Jan 2018
    • 8
    [CQ] Help TA4551ci Print Issue
    Guys, please help, i can't figure out why my black is like this
    ta4551.pdf
  • Max
    • Oct 2011
    • 555
    Re: Help TA4551ci Print Issue
    What have you tried so far?
    • lightningazure
      • Jan 2018
      • 8
      So far i have been able to swap Main Charger, but the problem still the same.
      I tried opening the platen cover to copy which should come out a fully black page, but all i get was whitish grey.
      Done Developer Refresh. U089 print out colour is fine, only black.
      As you can see in the picture, the black colour for the title is good, but otherwise is really bad.
      • gen67
        • Feb 2018
        • 5
        developer worn out .. get a new developing unit .. (maybe more then copies than made for or older then 3,5 years)
          • 22999
          I agree, it's undertoning. =^..^=
          • Scott
            • 196
            Developer unit
              is this from an end user or a " tech "?
              • Up to date Tech
                • Jan 2018
                • 31
                Yep devalper you can try swapping it with an other color for testing
                  • 22999
                  Just to clarify, you'll get an error code is you try to install any other color than black in the black developer port. =^..^=
                  • Scott
                    • 196
                    Ya I wouldn't put a color DV unit in a black. 1 it may not even fit in the unit and 2 it will code out
                    • protec
                      • Feb 2005
                      • 25
                      Agreed. You can do this with the drums but not the developers.
