Taskalfa 2551 Large Black line
  • spiderman76
    • Mar 2009
    • 59
    Hi guyssssss !!! :-)
    See my attachment...
    I've changed : TR-8315A , TR-8315B , High voltage PWB , HVU2 but nothing changes ... :-(
    Any ideas ???
    P.S. : When printing , from the HVU card i can hear an unusual hum
  • Ropariva
    • 674
    See my attachment...[ATTACH]39486[/ATTACH]
    Any ideas ???
    Attachment is only 1byte?
    • spiderman76
      • Mar 2009
      • 59
      Re: Taskalfa 2551 Large Black line
      Ops.... :-)
      Repost Attachment
      • sparkycivic
        • Apr 2017
        • 348
        black drum/charger? black dv?
        try swap drum/charger to another color position
          looks like it could be charge roller in drum of maybe pick pawl has gouged the fuser roller.
          • spiderman76
            • Mar 2009
            • 59
            I have already change drum K , Dv k and MC K but without results
              check the fuser
              • protec
                • Feb 2005
                • 25
                Have you tried another transfer belt?
                • itchyfinger@att.net
                  • Oct 2017
                  • 77
                  try stopping the paper in mid cycle and you can see what device is causing the problem
                    • 23008
                    It's still something black. Take a look at the drum ground or other charge contacts. You can apply conductive grease to the drum ground.
                    Do you have side voids where the bar crosses the page? The scanner creates voids even when there aren't any. If the the bar crosses the side voids it's charge related. =^..^=
                    • Scott
                      • 196
                      I am in the belief that it's the transfer belt. This model has issues with it
                        • 23008
                        You know ... I had one of these transfer belt assy's apart for a broken gear in the cleaning unit. When I re-assembled it I missed one of the spring electrical connections at the front left of the primary belt unit. I got very similar bars like this. Then I noticed the spring just setting there in the paper clip pocket.
                        I wonder if that's important? =^..^=
                        • Ropariva
                          • 674
                          Hi
                          I agree with the transfer belt
                          If an administrator is reading this post can they please contact me as currently there is no way to reset my password or contact admin as the captcha verification is now shut down.
