TA 5551ci color gray scale off when printing files
  • craigster
    • Apr 2016
    • 201
    [CQ] TA 5551ci color gray scale off when printing files
    Looking for some ideas on a TA 5551ci while printing files from usb and computer the color gray scales are way off also when scanning and copying the same issue and solids are fine. u89 they come out perfect, color registration is right on.
    things I have tried are:
    developer refresh, drum refresh, toner curve, test charts for scanning, latest print driver, latest firmware, reset factory defaults, changed emulation on printer and driver, tried files on a different printer they come out fine, changed out all consumables just to see if any change and nothing. Ordered a main controller. Also when I did the test charts for scanning it did not change anything. I even hooked my laptop up to machine to eliminate any network issue. No error codes on event log.
    • 22997
    Re: TA 5551ci color gray scale off when printing files
    Those are all the things that I would have done. =^..^=
    • craigster
      • Apr 2016
      • 201
      Update!! Memory was the issue! one thing I did not do was initialize memory! I put a used controller from a different machine and no change.
      copies scans and prints are perfect!! crazieness
        • 22997
        Thanks for following up. =^..^=
