2551ci transfer belt auger backing up
  • Devdumper
    • Oct 2017
    • 34
    [CQ] 2551ci transfer belt auger backing up
    Hi, I have a 2551ci auger keeps locking up and breaking the waste gear. They call for lines and background. Belt can't wipe because auger is jam backed. Already replaced belt. Taken it apart about 3 times and cleaned. Waste is getting out. Nothing stopped up all the waste waste bottle. Anyone seen this? Only about 300k . Thanks
  • Ropariva
    • 637
    Re: 2551ci transfer belt auger backing up
    • 20gaugeO/U
      • 553
      Bulletin 2NP-0017 (F162)
      New P/N: 302K094042 PARTS PIPE TRANSFER CLEANING ASSY SP
      • sparkycivic
        • Apr 2017
        • 348
        schedule lots of time to tear apart the entire front and LHS of the machine for replacing that "parts pipe transfer cleaning assy".
        In hindsight of having done this a few times - a few well-placed holes in the front inner-unit cover would really go a looong way to reducing the service time for this issue... like, it's probably totally worthwhile to create a drilling template!
        • Devdumper
          • Oct 2017
          • 34
          Thanks all.
          • Devdumper
            • Oct 2017
            • 34
            Rep. Auger assembly and transfer belt. Sure enough the half moon shaft on the auger pipe transfer cl. Unit was turning inside and not putting the waste out into the bottle. Thanks!
            • Tonerkiller
              • Oct 2012
              • 665
              I am having trouble finding that bulletin
              • George J
                • 107
                Yeah a lot of work to remove 2 screws... with a bit of practice you can replace the part and have the machine running in 30 ~ 40 minutes.
                also I believe the latest version of the pipe assy ends in 3 these days.
                • FWITIW
                  • Oct 2017
                  • 14
                  Did you find this bulletin? I can't find it either.
                  • 20gaugeO/U
                    • 553
                    Go into the IE Service Portal and search 2NP-0017 (F162), dated August 22, 2016
                    11 Page Document
