Kyocera 3010I doc. feeder troubles..
  • jper34
    • Sep 2011
    • 225
    Hey Folks,
    have a customer with a 3010I series, and the document feeder, intermittantly willjam..I noticed the lower plate not always lift up...I removed solinoid, clean and put a drop of oil on the plunger...worked for a little bit...has anyone encountered this trouble..?
    I'm guessing I need to order a solinoid, but thought I'd check for any other input..?
    Thanks,
    Jaime
    I.C.S.
    CT.
  • mincopier
    • Dec 2015
    • 289
    Re: Kyocera 3010I doc. feeder troubles..
    Check the width sensors on the feeder. They are attached to the front and rear guides underneath. Have sent the contacts get dirty and not read the proper size paper.
    • jper34
      • Sep 2011
      • 225
      would that cause the lifer plate, to not lift?, whats happening, is that lifter plate doesnt rise up, so the pick up rollers spin, but the paper is too low position, to grab the paper.
        • 23009
        Oiling a solenoid is the surest way to make it misfire. Start by soaking out both parts in alcohol then cleaning the bore with a Q-tip. =^..^=
        • ntbann
          • Jan 2012
          • 628
          Just had one that the post snapped off the lift plate. Not a good design.
