7002i says processing. Sits there.
  • Devdumper
    • Oct 2017
    • 34
    Hi. I have a 7002i. Will can the org. On glass or feeder. Says processing but just sits there. No error codes. Just will not print. Swapped fuser and updated fw. No help. 906. Unplugged also. No jam sensors blocked. Will not also print internal. Stays in status job. Any ideas.
  • Devdumper
    • Oct 2017
    • 34
    Re: 7002i says processing. Sits there.
    Wow this a good one. Called hotline. They said they were stumped when they first had this. He asked me to leave open 3&4 cass. Make it use only the two top trays.it worked! There was a tiny jam jammed back in the no.3 feed unit. Didn't see it at first. It will not show and jams of lift error c codes. Took it out. Rock and roll.
    • Zesti
      • Jun 2009
      • 311
      Wow....
      That's kind of TIA......
        • 23010
        Nice! Thanks for sharing! =^..^=
        • kjg
          • Mar 2009
          • 112
          Thank you for sharing!
          good heads up info.
          • Raymondd
            • Jan 2008
            • 108
            Just had the same thing.
            Thanks for sharing!!!
            • Devdumper
              • Oct 2017
              • 34
              NP.
              • JR2ALTA
                • Feb 2010
                • 2033
                I'm not clear. If the scrap is in (example) tray 3, no tray will work?
                • progoffice
                  • Nov 2008
                  • 337
                  Yep. Seen this one before too. It also can happen on the older 00 and 01 series machines.
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1901
                    I had it on an 8001i today. I wish I would have known this before I replaced the fuser, HDD's, memory & firmware.
                    It is worth bumping it up so someone else might see it though.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • Mr2crazed
                      • Jun 2014
                      • 35
                      Wow, that's some good info. I'll have to file that in my memory bank. But that means I'll have to delete something from memory.
                      • paul.felton2
                        • Feb 2019
                        • 13
                        Thanks, great info just had a TA8353ci with exact same issue, pulled 3&4 out and away she went...
