KM-8030 J65
    • 23006
    KM-8030 J65
    I thought that I'd seen everything on the Harrier ... well but this. It started with a J00 jam that wouldn't clear. That came down to DUP CV SW A (DUPCSW1), and a new switch resolved that. Now I can simplex, but will pass only one page duplex before jamming J65. The paper stops about 25mm shy of DUPCSW2. There aren't any obvious snags or skid marks from the duplex rollers. The lower guide closes properly, the rollers meet evenly, and they have good grip on the paper. The one-way bearings don't slip, have been cleaned and oiled. All the rollers have been cleaned.
    The only roller I have any question about is the duplex switchback roller. It's only worn 0.3mm smaller circumference towards the front (far less than the 1.3mm it takes to cause J60, J61, J62, and J63 jam codes, but it's the only promising lead that I've got).
    Has anyone seen J65 jams?
  • Santander
    • May 2009
    • 768
    Re: KM-8030 J65
    Had a 6030 driving me crazy a few months ago with duplex jams. Do not remember the exact jam code(s) and searching the database did not bring up a J65, but what resolved it for me was replacing the solenoid in the duplex unit. I had gone the same route you have replacing rollers and making sure everything was clean and the one way clutches worked properly. What was really annoying was I would try different things as you have only to have it work for a few days. I had essentially rebuilt the duplex unit except for the solenoid assembly only to have it jam again. Once I replaced the entire assembly, solenoid, spring etc. have not had a duplex problem since. Apparently the solenoid would randomly not engage completely and did not apply enough pressure on the feed roller causing a late arrival jam code. I guess that after 3.8 mil on the clock you have to expect some weird problems. Hope this helps.
      • 23006
      Re: KM-8030 J65
      Originally posted by Santander
      ... Once I replaced the entire assembly, solenoid, spring etc. have not had a duplex problem since. Apparently the solenoid would randomly not engage completely and did not apply enough pressure on the feed roller causing a late arrival jam code. I guess that after 3.8 mil on the clock you have to expect some weird problems. Hope this helps.
      It would certainly account for a late arrival. I guess I didn't mention, 900K prints. That will be attempt #3 ... if we get that far. =^..^=
        • 23006
        Re: KM-8030 J65
        Still no success. Does anybody have a parts donor? I'd like to replace the switchback solenoid and/or duplex PWB. Please send as Private Message. Thanks. =^..^=
        • NeoMatrix
          Senior Tech.
          • 3513
          Re: KM-8030 J65
          Try cleaning/polishing grey oxides off the solenoid plungers with a very light sand paper. I've had a few plungers gum up over the years, an I've got them going again.
          Knowing your expertise you would have covered everything, eg rough up/sandpaper the shafts on all one way bearings. I'm leaning towards a lazy sensor causing timing delay in the duplexer...
            • 23006
            Re: KM-8030 J65
            Yeah, tried that. Scrubbed the hell out of the switchback solenoid plunger, and tapped it with a hammer. I got 1 maybe two pages through duplex before it jammed up. I found two sensors: DUPSCW1 got me out of the J00 loop and let me simplex. I swapped the other new sensor into each of the other locations with no change.
            The reason I mention the duplex PWB is because I've had quirky duplex behavior after the fuser drive dusted the duplex board with iron oxide dust, creating new current paths. On one occasion cleaning off all the conductive dust helped for a while. In the end though I ended up changing the duplex PWB in both cases. =^..^=
