Taskalfa 4500ci temperature warning
  • quitech
    • 82
    Hi
    Please if taskalfa 4500ci display this massage, [warning for high temperature. Adjust the room temperature] please what can I do please
    • 23010
    Re: Taskalfa 4500ci temperature warning
    Hmmm.
    What is the room temperature? =^..^=
      • 30455
      Check the filters and clean or replace . Also check that all cooling fans are running
      Of if machine is up against the wall
      • quitech
        • 82
        Hmmm.
        My good friend black cat, greetings to you,it has been long, thanks for replying. I don't know the room temperature, that is what the machine is showing. I suggest may be is course of the dead display cause by the main board
        • copier tech
          • 8196
          • quitech
            • 82
            Thanks a lot copier tech for this information
