3252ci memory light blinks
  • tee
    • Aug 2014
    • 79
    We installed this to replace a Taskalfa 3051ci . The old unit never had a call.
    We replaced main pwb, HDD, and fax board. The memory blinks after we plug in the LAN.
    There is no internet access. The machine locks you out of service mode.
    We took a 5052ci into the location and the symptoms are the same.
    We are doing a packet capture next. Any ideas could help. Oh yea there are no jobs in job status.
    • 22999
    Re: 3252ci memory light blinks
    I would suspect that something other than a print driver is sending data to this printers IP. A simple test would be to print directly via crossover from your laptop. If that works try changing the IP to a different unused address. =^..^=
    • Ropariva
      • 655
      • tee
        • Aug 2014
        • 79
        The problem here is that Calgary, Alberta has to get the mac address and assign an ip.
        The 5052ci we took and had the same symptoms was just plugged into the
        network and didn't get the ip address assigned. IT STILL had the memory light flash.
          • 22999
          ... and printing directly from the laptop? =^..^=
          • tee
            • Aug 2014
            • 79
            yes, laptop works every time with no memory flashing
            • darry1322
              • Oct 2010
              • 817
              Try taking it off auto detect network speed. I've had a few issues that were resolved by setting the network speed manually.
              • wragsdale
                • Jul 2014
                • 188
                If that's a DHCP reservation, you can still just turn off DHCP and set a static IP to test.
                Was the 5052ci connected to the same drop or switch?
                • darry1322
                  • Oct 2010
                  • 817
                  We just had one with the flashing memory light. It turned out to be an old TA3050 driver being directed to the new printer. Changed to correct driver and all is good.
                  From ntbann on another thread.
                    • 29929
                    What happen if you plug your laptop in, does it get an IP address?
                    See if you can plug copier into a different data port in the area and try,
                    Agree have them assign a new Ip address for the copier and load a new driver
                    KX driver set to pcl5e
                    Also ping the ipaddress with the data cable unplugged , maybe a another device using that same Ip address
                    If its using the same ipaddress as the old unit did IT update the current new machine MAC address in the DHCP reservation? If not that's the issue.
                      • 29929
                      On an enterprise size network IT may have network locked down an may not give out an ipaddress. The copier will try to pull a dhcp address and will time out. I had many fortune 500 companies locking there networks.
                      • callservice
                        • Sep 2011
                        • 26
                        Network related problem... connect the machine in another point or another floor in the same network..Some time the network switch also doing this Job...Connect your old TA-3051ci and assign the same IP address.. if any print driver related issue TA-3051ci will not work..if it is working ok,then you have to break your Head...
