KM-2560 dev replacment
  • mickeyc123
    • Apr 2013
    • 18
    [Misc] KM-2560 dev replacment
    hello,
    ive not worked on this older model before.
    i have a new dev unit, DV-420.
    it came empty of dev, how do i fill it?
    is it filled from the toner cart?
    cant find a maint mode to fill the dev unit.
    help please?
  • darry1322
    • Oct 2010
    • 817
    Re: KM-2560 dev replacment
    MM130 fills the developer unit.
      • 23003
      Stratos uses mono-component developing, so there is no developer (or it's all developer, depending on how you think of it). U130 fills the developing unit. It takes about 5 minutes based on the piezo sensor, and uses about 1/3 cartridge of toner, so have a spare on-hand if it's low.
      If you want to you can dump the toner from the old unit into the new unit, then run U130. It will finish quicker and is less wasteful.
      It's not uncommon to get some mottling on a new fill. When the developing unit is full, you can remove it again, and dry-wipe the developing cylinder to smooth out the clumps. =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        After 10 years of this model being released, I'm assuming his natural follow-up question will be "thanks but what the hell is mm130 and/or u130?"
        • mickeyc123
          • Apr 2013
          • 18
          thanks for the help guys!
          got it sorted and noted MM130 in my cheat sheet for future use.
