3552ci C7109
  • Synthohol
    Certified Konica Expert
    • 5823
    3552ci C7109
    machine showed C7109 (black drum EEPROM failure)
    after hours of being mislead and trying every board and wire harness, it turned out to be the Cyan DV unit had failed throwing this error which should have nothing to do with cyan at all.
    just a warning to hopefully save you some time if you get the error and replacing the drum does not fix it.
  • Zesti
    • Jun 2009
    • 308
    Re: 3552ci C7109
    Synthol,
    I've seen ur post on Konicaminolta forums, and know what I hane most experience on Konica's and was looking for some help on Kyocera's found your post and curiously opened it to find it for the Kyocera also.
    Coming to main point, as I mentioned I work on the Konica's, sice last 13 years and have have good grip on these. Just to mention we have a large quantities of off lease machines imported from US and EU markets. I was looking to put hand on the Kyocera's as many machines are available at cheaper rates but carry with them their problems, main one is the corrupted firmware due to power failures or fluctuations, main models available here are TA 420 to TA 820 and them TA 3500 series, 3501 series TA 6500, 8000 and many more between and after them. No one is providing services for these models and sold machines are lying dead, mostly because of corrupted firmware, so visited today copytechnet looking for some help ....
    So...anybody ....
    • Synthohol
      • 5823
      Re: 3552ci C7109
      PM me a list of what firmwares you need and ill see if i can hook you up!
        • 23007
        Re: 3552ci C7109
        Thanks for sharing. I'm imagining it was a long, twisted road to the solution. =^..^=
