M3550 Knocking sound ?
  • tech07
    • Aug 2008
    • 409
    Have a M3550 with a knocking sound. Not real loud, but don't trust it. Has almost new pm kit. And new dev. and reg. clutches. Runnng fine but knocking.
    Not the fuser. Hard to pinpoint source. Drum, fuser, developer less than 10K. This machine runs 75k a month. This knocking noise has me frustated. ?????
    • 22999
    Re: M3550 Knocking sound ?
    Paper tray lift gear post broken? =^..^=
    • darry1322
      • Oct 2010
      • 817
      I did see one machine ( can't remember if it was an M3550 but it was similar) that wouldn't knock during pre-drive if the drum or developer or toner wasn't in the machine. If you just left the toner out with everything else in place, it wouldn't knock during pre-drive. Put the toner in and the knock during pre-drive would be back.
      Turned out to be the fuser. Apparently the fuser pressure doesn't engage until every component is detected. The knock was only present when the fuser pressure was engaged.
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5007
        slow knocking=Paper tray lift gear post broken
        fast
        knocking =registration gear
        • tech07
          • Aug 2008
          • 409
          Thanks guys. Definitely not tray lift. Changed way too many of those.
          Registration gear sounds interesting
          • zoraldinho
            • Mar 2008
            • 5007
            302LV24160 - Gear Z19R-Z22R RGIST UP
            302LV24150 - Gear Z22L REGIST LOW
            • tech07
              • Aug 2008
              • 409
              Could not locate 302LV24150 and 160 in the M3550 parts list.
              • tech07
                • Aug 2008
                • 409
                Part not in parts manual but found it in service bulliten...Thanks !
                • zoraldinho
                  • Mar 2008
                  • 5007
                  Any time.
                  • tech07
                    • Aug 2008
                    • 409
                    Solution was found in Drum assembly component of new PM kit ( 10k ). Turning too tight causing spring loaded drum coupling ratchet gear to slip and make noise. Thanks for input.( Will pay attention to reg. gears going forward also.)
