CS 2552ci C6600 CODE
  • Intone
    • Apr 2015
    • 68
    Have taken out the fuser, fuser looks good. Code resets but comes back after a while. Tried latest firmware today didnt fix it. Anyone else have this issue? Going to try tech support tomorrow. Thank you in advance.
  • patrickjlc
    • Feb 2015
    • 225
    Re: CS 2552ci C6600 CODE
    It nay look good, but the thermistor or fuse might be bad giving you a code even though you reset the error. Fix it, then reset.
    Sent from my SM-G930V using Tapatalk
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1888
      Bulletin H178. Replaced the fuser.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Santander
        • May 2009
        • 768
        We have not had this issue, but the C6600 relates to the machine not seeing the fuser belt rotating for 1.8 seconds. That would indicate that the fuser is binding up and not reaching the rotation speed expected by the machine. Since Kyo only sells the fuser assembly and not any of the internal parts, you will probably have to replace the whole fuser assembly which would be covered under the warranty.
        • masterchill
          • Jul 2005
          • 100
          On these you can grab the bushings on either end of the fuser roller and if you can turn them separately the fuser is bad.
          • CleanTheSlitGlass
            • May 2018
            • 19
