Kyocera Ecosys M2540dw - skew
  • kuby
    • Oct 2007
    • 1400
    Got a new machine in today and the image is skewed about 3 mil. There is not adjustment for the scanner and nothing I can find to adjust the paper skew. Any help would be appreciated or just send it back?
    Well I did find a adjustment procedure U411, have to have test originals to do them, ChartA 302NM94340 and ChartB 302NM94330.
  • Ropariva
    • 671
    • bigdaddy
      • Feb 2015
      • 35
      Re: Kyocera Ecosys M2540dw - skew
      Kuby-
      Did you find a fix for the skewing? I have 35 of these to install and the first 3 out of the box are skewing, needless to say I haven't un-boxed the the other 32 yet. Any information would be helpful. THANKS!
      • kuby
        • Oct 2007
        • 1400
        No it did not fix it. Got a new machine and it does it too. I guess it is the nature of the breast?
        • bigdaddy
          • Feb 2015
          • 35
          Thanks, I was hoping you found a fix. I'll call work support, and hopefully they will have a solution, or at-least i will have a case number for the Regional Tech.
          • JR2ALTA
            • Feb 2010
            • 2033
            Please temper your expectations. It's a desktop unit. If people need a digital scan without much fuss it'll do.
            • Geo
              • 662
              Is the image skewed equally from top to bottom?
                • 23007
                So did you determine if it's a paper skew or an original skew?
                I had a tabletop B&W printer that was skewing ~3mm from all the trays. I was able to completely remove the paper skew by installing a longer pressure spring at the pre-registration roller.
                The spring at the left is the original. The spring in the center is the replacement that I used. The spring at the right was too strong and the idler shaft would not stay clipped in long enough to install the rollers (they launched across the room). I can get measurements and model numbers, but I think you get the basic concept. =^..^=
                • djs9164
                  • Mar 2018
                  • 79
                  [ATTACH=CONFIG]42090[/ATTACH][ATTACH=CONFIG]42091[/ATTACH]
                  Unofficial fix. Shim the rear side of your fusing unit.
                  Sent from my XT1635-01 using Tapatalk
                  • ntbann
                    • Jan 2012
                    • 628
                    We had to shim a fuser on a M3550 that was skewing bad with legal paper.
                    • Geo
                      • 662
                      Actully it's an official fix..
                      • Hose1cook
                        Defective Technician
                        • Jun 2008
                        • 80
                        I have a few doing this, one I just set up today. Is there any documentation? I just searched the QA's and nothing came up. Thanks.
                        • ntbann
                          • Jan 2012
                          • 628
                          Make a shim, put it behind fuser mount, reattach fuser, test. If still skewing try more or the other side of fuser.
                          • bigdaddy
                            • Feb 2015
                            • 35
                            Regional Tech came in today and with the test charts not printing skewed determined that the internal prints were skewed. With the test charts the skew dropped to no skew to half a mm.
