Taskalpha 3051ci print quality
  • johnny32
    • Oct 2007
    • 102
    Hi all
    Was wondering if anyone has come across the print quality issue i am having intermittently on a utax 3005ci\Taskalpha 3051ci.
    To date the charge roller and transfer belt have been changed and the issue dissappears but is one of thoses that comes back every now and then but is usually gone by the time we arrive on site and cant get to recreate the issue.
    Please see the attached as an example of the issue. The back round of the page should be cream not multicoloured
    20180731163647426.pdf
    • 22699
    Re: Taskalpha 3051ci print quality
    Does the magenta background extend out the edge of the paper, through the voids? Did you do a color calibration after either of these parts replacements? =^..^=
      • 22808
      Originally posted by johnny32
      Hi all
      To date the charge roller and transfer belt have been changed and the issue disappears but is one of those that comes back every now and then but is usually gone by the time we arrive on site and cant get to recreate the issue.
      Please see the attached as an example of the issue. The back round of the page should be cream not multi-colored
      [ATTACH]40276[/ATTACH]
      you changed out the belt ... did you run the calibrations needed when installing new?
        • 22808
        Sorry BC I didn't read when you had asked this... I wouldn't have bothered.
        • Scott
          • 185
          Toner curve adj, if that doesn't fix it a Magenta DV unit
          • johnny32
            • Oct 2007
            • 102
            All install cslibrations done for the units and all sky shots of dev units ok.
            • Ropariva
              • 591
              • daveh12
                • Jul 2012
                • 157
                run AC Calibration in U464 everytime you visit these machines to avoid this exact issue. if you run it now after checking the magenta unit it should be fine. no need to replace. what count is on the Developer?
