Black print in copy mode FS-6025MFP
  • kaborwen
    • Feb 2010
    • 146
    [Misc] Black print in copy mode FS-6025MFP
    Hi,
    I got an issue with ECOSYS FS-6025MFP. When printing, no probleme. But when copying, it's come out with black print. I replace ISU, but not ok.
    Someone have solution?
    PS: See Attached file.
    • 23009
    Re: Black print in copy mode FS-6025MFP
    What do scans look like? Did you do a scanner calibration?
    I think that I would have started with re-seating cables, then the CCD. =^..^=
    • Santander
      • May 2009
      • 768
      Originally posted by kaborwen
      Hi,
      Since you state that printing does not have a problem, it is narrowed down to scanning the original for copies. Is it from the ADF only or from the platen as well? If you are getting this from the ADF only check to make sure that someone has not dislodged the scanner lock lever resulting in the scanner not get to the home position when using the ADF, platen copies are OK. Had one a couple of months ago that exhibited the same output only to discover that someone had moved the scanner lock lever half way and it kept the scanner from fully getting to the proper position when using the ADF. Platen copies were fine. Worth a look.
      • kaborwen
        • Feb 2010
        • 146
          • 23009
          You know, I remember something. I remember the black scans. This series would blow engine boards. They were covered under warranty for a while. =^..^=
          • Santander
            • May 2009
            • 768
            If prints are OK and it can scan from the platen OK, then I would suspect that something is keeping the scanner from reaching the home position to scan from the adf. The scanner cannot get to the proper position when using the ADF and it is scanning the frame between the slit glass and the platen. Is the alignment of the ADF to the machine OK? If the ADF has been abused it may be skewed to the point that the documents are beyond the scanning point of where they should be for the ADF. There is an adjustment for ADF skew located in the compartment that houses the microcolth on the backside of the ADF. However I still feel that your scanner is not getting back to the home position for the ADF. Have you replaced the scanner home position Sensor?
            • frodo
              • Aug 2009
              • 36
              Yes, It was common when the PSU went bad(Pregnant Caps) or blew, it takes out the eng/main board, and then you get black scans/copies.
              • kaborwen
                • Feb 2010
                • 146
                There is no ADF. The machine working with platen and do black copies.
                • kaborwen
                  • Feb 2010
                  • 146
                  So in this case, what can I do? Order MAIN PWB or ENGINE PWB?
                  The machine is out of warranty.
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    I take their suggestions as to replace both.
                      • 23009
                      There's a bulletin. I'll see if I can find it.
                      You can look too. =^..^=
                      Apparently the FS-6025MFP is not sold in my area, but this is the bulletin for another Matsuri. Obviously the part number won't be the same.
                        • 23009
                        Hey, I just had a thought. Did you maybe accidentally 1/2 lock the scanner so that it can't reach the slit glass anymore? It's easy to do, just moving the machine around. =^..^=
                          • 23009
                          ... If you are getting this from the ADF only check to make sure that someone has not dislodged the scanner lock lever resulting in the scanner not get to the home position when using the ADF, platen copies are OK. Had one a couple of months ago that exhibited the same output only to discover that someone had moved the scanner lock lever half way and it kept the scanner from fully getting to the proper position when using the ADF. Platen copies were fine. Worth a look.
                          Oops! I just noticed that I'm about 3 posts too late. =^..^=
                          • frodo
                            • Aug 2009
                            • 36
                            If you have already changed the Power supply, you'd be pretty safe trying each one (NOT BOTH AT THE SAME TIME) and remember the dimm / eeprom, In the colour machines it was usually the Main pcb from memory.
                            Also make sure you have the latest firmware at the end, as they did make changes to the power settings to "try" and stop this from happening.
                            • albenbalinong
                              • Sep 2015
                              • 30
                              Please check the scanner ribbon wire as well..
