Black print in copy mode FS-6025MFP
  • kaborwen
    • Feb 2010
    • 146
    #16
    Re: Black print in copy mode FS-6025MFP
    There's a bulletin. I'll see if I can find it.
    You can look too. =^..^=
    Apparently the FS-6025MFP is not sold in my area, but this is the bulletin for another Matsuri. Obviously the part number won't be the same.
    BIIINGOO!!!!! You right. It's was PARTS PWB MAIN ASSY. After replace, all right.
    Thanks you very mucht.
      • 22973
      #17
      Congratulations on your success. =^..^=
      • azharali899
        • Jan 2019
        • 1
        #18
        Originally posted by kaborwen
        Hi,
        I got an issue with ECOSYS FS-6025MFP. When printing, no probleme. But when copying, it's come out with black print. I replace ISU, but not ok.
        Someone have solution?
        PS: See Attached file.
        scanner led light problem
          THE OP JUST SAID IT WAS THE MAIN PCB! no points for you!
          • sparkycivic
            • Apr 2017
            • 348
            #20
            i had the similar machine (fs-c8520MFP) do exactly this, turned out to be the EEPROM. Had to order new eeprom from Kyo for that machine.
            Keep this in-mind when all else fails... try an eeprom/from working unit to test
              The main PCB holds eeprom correct?
                • 22973
                #22
                Correct sir. =^..^=
                  Correct sir. =^..^=
                  Thanks Brother,
                  so if you take a bad eeprom off a bd.. and a good one off a working bd... now you have to 1) try and reprogram the bad chip ( ? results ) 2) put the good eeprom on the org bd and reset... seems to me wouldn't it be time/cost effective to just replace main pcb.. reset and be done?
                    • 22973
                    #24
                    The EEPROM on the new board is blank, no data. The old EEPROM contains machine identity and counts, must be programmed by the manufacturer AFAIK. Just swapping EEPROMS will result in error codes, identity issues. I would avoid that rabbit hole if at all possible. =^..^=
                    • sparkycivic
                      • Apr 2017
                      • 348
                      #25
                      swapping eeprom causes code, and u004 to fix. New engine board comes with no eeprom installed, so this is normal engine board "replacement" procedure.
                      It WOULD be simpler to just swap working engine/main pair from working cadaver for testing. I spent 8+ hours troubleshooting every component and cable with kyo rep present, before eeprom conclusion when the issue was last seen in our shop. Never would have thought the eeprom could even cause such a thing, but it did.
                      The machine was a used device working fine when originally returned, but somehow failed a week after installation in it's new home.
                      after new eeprom from kyo, that machine ran for several more years until permanent retirement.
