C8525 dropping dev. Grit everywhere.
  • Devdumper
    • Oct 2017
    • 34
    [CQ] C8525 dropping dev. Grit everywhere.
    Hi. I have around 200k on an c8525. Customer called complaining of gritty copies. Seems that developer is dropping out of one of the units or units. I'm pretty sure it's the k one but all the units looked clean. Color copies and black look really good. Transfer roller was full of dev. And I vacuumed everything out even the first feed unit. Was jamming also because dev was everywhere causing things to slip. Units look good with no developer hanging from them even k on arrival.. Any ideas would be appreciated. Thank you! Confused.
    Re: C8525 dropping dev. Grit everywhere.
    ok other than vac the unit what have you done?
    life on DRUMS?
    what are the bias settings? ( poor or over bias can cause dumping )
    LOOKS GOOD doesn't mean they ARE good.
    • Devdumper
      • Oct 2017
      • 34
      life on DRUMS?
      Thanks. Going to check when I get back. Customer was leaving as it was 5pm. Thanks for the advice. I will check on next visit.
