FS3040 Paper Meandering
  • OperatorError
    • Aug 2017
    • 21
    My machine will run single sided all day long. Running duplex the paper drifts to the left and eventually runs out of the paper path and crashes.
    I included a picture of the rear of the machine with the fuser removed. The paper is in the duplex tray, you can see the left side of the paper is against the edge with no room for error, the right side however looks fine. Also is a picture of the jam under the drum when the paper is so far it crashes.
    Customer does not run labels, no scraps of paper found, no springs or idle rollers out of place. No issues under the dev unit. Machine only has 36k, fuser is newer.
    Jam is code is usually 70 but the the drift is the problem.
    Anyone seen this before? Or I am in for a huge disassemble.
    Thanks in advance.
    20180918_170507_resized.jpg20180918_170459_resized.jpg20180918_165937_resized.jpg20180918_171209_resized.jpg
  • Gary E
    Re: FS3040 Paper Meandering
    Replace the paper tray.
    • OperatorError
      • Aug 2017
      • 21
      Thanks...What is the reason? I know the contour of the cassette secures the duplex tray in place and appeared to be doing just that when i looked in thru the back of the machine.
      • Scott
        • 196
        Don't think its paper drawer, once it's out of the drawer it doesn't go back and it doesn't do it on single sided. The problem is somewhere in duplex unit. Try different drawers and see if it quits and manual BP
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1888
          It's a known issue. Pull the center gear out of the cassette & move the left guide in one tooth & reassemble. Guaranteed to fix it.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • OperatorError
            • Aug 2017
            • 21
            Sounds promising, thanks. I wish the first guy would've gave a pinch of reasoning behind his (correct) solution. I am going back tomorrow and hope for the best. By the way, how is this a known issue? Just word of mouth or a bulletin? I didn't see anything in my searches.
            Thanks again.
            • mita
              • Sep 2010
              • 87
              I have also seen the mylar shim where the fuser mounting screws are can cause skew. There usually is a shim on one side, swapping the shim to the other side resolved the issue.(Front to rear)
              • OperatorError
                • Aug 2017
                • 21
                It was not the cassette...or the duplex unit...or the exit unit.
                After tear down I found these large vertical feed rollers behind the bypass tray. As you can see the one on the left is not centered on the hub. The right was biased to the left as well but harder to see in the picture.
                Single sided worked but going past this roller twice was enough to cause those intermittent jams.
                Hope this helps someone in the future.
                  • 23009
                  Good to know! Is the photo after the re-aligning? I can't really see the rubber riding off the side of the pulley, but I can imagine what you're talking about.
                  Thanks for posting back. =^..^=
                  • OperatorError
                    • Aug 2017
                    • 21
                    Not so much riding OFF the pulley, just cattywumpas towards the left. Here it is with a computer generated line, you can see the gap towards the bottom where the hub rail is.
                      • 23009
                      Dis you replace the roller or find a way to align it? =^..^=
                      • OperatorError
                        • Aug 2017
                        • 21
                        I worked some windex behind the rubber to help it slide. Straightened and hoping for the best. Looks like a pain to replace and this machine is already a 2 week headache.
