taskalfa c8160 intermittent error
  • Stevea
    • Sep 2018
    • 1
    Hi any one had c8160 on internal finisher, reset code and works for a while
  • KYO_OEM
    • Aug 2011
    • 727
    Re: taskalfa c8160 intermittent error
    Maybe tray would blocked during moving by something, or tray holder deformed.
    • Santander
      • May 2009
      • 768
      Since you say resetting the code works for a while, I would suspect that you have a sensor flag hanging up randomly. What model are you working on? A little more info would help nail down what is going on.
        • 23010
        ... nope, I can't guess. Maybe you can tell us what model you're talking about. =^..^=
        • trevorgee
          • Dec 2010
          • 4
          I am getting C8160 on a few taskalfa 4052ci with the inner finisher, seems to be a problem when the exit tray lowers,gears ,belt and motor look ok.
          Anyone had this issue?
          • temas
            • May 2011
            • 22
            I am having same issue on a TA 3552ci. Internal finisher 7100.
            > upgraded firmware
            > used U240 to check DF tray motor operation ( moving fine when exit tray is cascaded but jerks when tray is extended to receive A3 for example)
            > also noticed 2 ball bearings for the Exit tray lowers are stiff and two are very free
            > gears, belt are ok
            >worm gear on motor is fine.
            Any help will be appreciated. This is Weird.
            Do not find fault, find a Remedy, anybody can complain.
            • craigster
              • Apr 2016
              • 201
              [QUOTE=temas;1052928]I am having same issue on a TA 3552ci. Internal finisher 7100.On those internal finishers I have had a spring break causing the tray to jerk when it lowers causing jamming. the spring keeps tension when trays moves downward
              • temas
                • May 2011
                • 22
                [QUOTE=craigster;1080619]
                could you please point out the Spring to me here? see the attached.
                i couldn't find any as part of the tray mechanism.
                • craigster
                  • Apr 2016
                  • 201
                  So the spring that breaks on me is in the paper feed section in df7100 parts fig 3 item 19 spring guide upper. You can reform it and will work until you get a new one assuming that is the issue. I would advise removing finisher from machine to remove some covers from it.
                  good luck
