TA 3500 Light copies Changed Drum Dev Chrge & toner.. OK for 3 weeks Then light
  • Doug James
    • Jan 2012
    • 935
    [CQ] TA 3500 Light copies Changed Drum Dev Chrge & toner.. OK for 3 weeks Then light
    I installed this used machine about a month and a half ago. Was running great. Then about 2 weeks the machine started printing light copies. I changed the Drum, Dev Housing Charge roller and gave them new toner then the machine was back to running great... Now we are back to light copies. I cannot find the Economy toner button thinking this would explain it. Assume it doesn't have it... Any help would be very appreciated...
    • 22930
    Re: TA 3500 Light copies Changed Drum Dev Chrge & toner.. OK for 3 weeks Then light
    How about a sample?:
    • Doug James
      • Jan 2012
      • 935
      I just got the "call back" this evening. Going there in the morning and I will post a pic. Thanks so much !!
      • Doug James
        • Jan 2012
        • 935
        Here are some sample pics as to what the machine is doing. The ANSI Test patterns were printed from a flash drive...
          • 22930
          hmmm. Nice and even ... just overall too light. Generic toner? What does the latent developed image on the drum look like? =^..^=
          • Doug James
            • Jan 2012
            • 935
            It's Generic toner but I use it on other machines and don't have a problem. Currently the latent image is light also. When I change the developer housing it will fix the problem temporarily then come back in a couple of weeks. The customer said they ran 2000 copies when it started this.
            • copiertec
              • Jan 2016
              • 2184
              Almost sounds like a toner density calibration issue. We only use OEM's in all of our Kyocera boxes because of such issues, I would start there. When you say you have changed the developer housing, do you mean you have installed a new developing unit? If not, I would also start with a new developing unit with OEM toner and see if the problem still occurs. Also, you could use U002 to reset any setting that may not be to factory specs, as well.
                • 22930
                It's the toner. And it will probably tone back up without changing the developing unit if your customer is patient. Just run a crapload of 70% black images once you get OEM in there. =^..^=
                • Doug James
                  • Jan 2012
                  • 935
                  Really appreciate you guys's feed back. I'm with ya'll... It's gotta be that. The generic toner just can't handle the big runs of 2-3000 copies. I will put the OEM toner and new dev unit in it and let you know... Sure do appreciate the response...
                  • copiertec
                    • Jan 2016
                    • 2184
                    Like Blackcat has mentioned, you could either run a bunch of skyshots at 70%, deplete the generic toner, then install the OEM toner, or replace the developing unit entirely. If you do replace the dev. unit, make sure you run the proper sims for setup, they usually come with the developing unit.
