Kyocera FS-C2026MFP color problem
  • tsbservice
    Field tech
    • 7635
    Hi All.
    Need help with this one. I'm doing mostly KM/Brother and Toshiba stuff, but large customer wants me to see this Kyo.
    The black text looks blueish and images look blurred.
    I have read here about problems with color registration related to IDC shutter and transfer belt and will check them.
    Have not access to Firmware or parts other than consumables, so any help
    would be appreciated.
    • 22698
    Re: Kyocera FS-C2026MFP color problem
    Lets start with a quality sample please. Try this:
    • tsbservice
      Field tech
      • 7635
      Yes, thanks to you Sir I have these color charts for some time on my phone memory and USB flash drive.
      Will try them when touch machine, any common problems with these?
      • tech07
        • Aug 2008
        • 405
        First of all, I'm sorry you have to service this machine, not a very dependable one.
        Do the color registation process in service mode and get it as close as possible
        Install specific firmwre for this issue.
        Fine tune in service mode again.
        PS. Before starting, remove and resesat drums, develoers and transfer belt.
        message me and Ill send firmware
          • 22698
          It's quite common to lose a single color completely. The drum and developing units often make poor electrical contact. Simply re-seating the drums and developing units can bring back the single color. Yes there is a firmware to improve color registration. Keep in mind that it is often necessary to run the color registration several times to achieve correct color calibration. I've had instances where it took (8) times to get color registration pulled back in. If your customer is hoping for photo quality they will be disappointed. =^..^=
          • tsbservice
            Field tech
            • 7635
            Nah BC, she is just secretary of big boss. They wanted me to fix it right now, by the phone:
            Thank you both for needed suggestions.
            • tech07
              • Aug 2008
              • 405
              Blackcat is correct. 8 times is not unusual
              • tsbservice
                Field tech
                • 7635
                Problem solved...
                In fact there wasn't REAL problem with the machine thankfully. But customers like this should be charged twice per normal just because of their stupidity.
                Went there print report from machine looks good...Hmm, go ahead and printed BC charts from PC, all of them looks pretty normal. After that got confidence to do calmly calibration and color registration(ONLY 3 times), I know I was lucky today
                At last she manage to find a file with the problem, printed again same blueish s**t. That file was scanned from another machine somewhere and they printed this ONLY file with problems and yelled for service.
                • Ropariva
                  • 590
                  Problem solved...
                  Bill, Bill Bill!!
