CS3010i DATA MIGRATION TO CS3212i
  • Intone
    • Apr 2015
    • 68
    Good afternoon,
    have tried to migrate data between machines in the past using the service mode sim but have yet to be successful. Is there a specific size thumb drive or anything that we could be missing. It is straight forward it seems but it never works. Thank you in advance.
  • darry1322
    • Oct 2010
    • 817
    Re: CS3010i DATA MIGRATION TO CS3212i
    Originally posted by Intone
    Good afternoon,
    You can't use 917 to directly move data from one model to another. They have to be the same model for that.
    You can use the Setup Tool to convert from one model to another using the 917 exported data as input and have it output data you can then use with 917 to import into the new machine.
    You can also use Kyocera Net Viewer to move the data from one model to another by putting them both onto the network or saving the data to a file to be uploaded using Net Viewer.
    Read the instructions for each to get the details.
    • Ropariva
      • 663
