How to fix fixing error code in km 3040
  • KHAN
    • Aug 2006
    • 261
    [Error Code] How to fix fixing error code in km 3040
    Hello friends i have KM 3040 copier ,The touch screen is not working but the copier is working for making copies , today we have FIXING ERROR in it So HOW TO RESET THIS CODE WITH OUT USING TOUCH SCREEN ?
    THANKS
  • patrickjlc
    • Feb 2015
    • 217
    Re: How to fix fixing error code in km 3040
    [ATTACH=CONFIG]41046[/ATTACH]
    THANKS
    You can do u201 to reset the touch screen and then do the u163 to reset the fixing unit error.
    On u201 touch the 3 plus marks to adjust touch screen. Use some alcohol or windex to clean the screen also.
    Sent from my SM-G930V using Tapatalk
    • KHAN
      • Aug 2006
      • 261
      Thanks friend for your reply , but my TOUCH SCREEN is Totally out of order.
        • 22973
        Then you'll have to fix the touch screen before you reset the fuser error.
        I had this exact same situation on a bizhub 350. Enduser needed a System Error Clear, but the panel was kaput. I told them the same thing. =^..^=
        • JR2ALTA
          • Feb 2010
          • 2029
          You could have debris pressing down on the screen. Clean all 4 edges with a thin card from your wallet. Clean it out good and deep.
          • patrickjlc
            • Feb 2015
            • 217
            When you touch the screen buttons do they do anything, like press A4 and shows Zoom, or does nothing at all?
            Clean the plastic covering the screen, the corners as someone posted.
            If nothing else, order a new touch screen glass from the web, and change it. Shouldn't take more than 10 minutes.
              did you EVEN try the touchscreen reset calibration process as described? you have to fix touchscreen issue before proceeding
              • KHAN
                • Aug 2006
                • 261
                Thanks friends i did all these tips , i replace an other complete panel RESET THE ERROR and fix the old PANEL again with the same copier,BANG
                THANKS to ALL
