TA 3500i 4500i 5500i drum and cleaning blades
  • Samanator
    • Sep 2017
    • 575
    Does or has anyone found just the drum and cleaning blades for theses machines? Do you know where to buy theses but not in a drum unit? Does anyone know the part numbers I could use to search for a drum and cleaning blade for these machines? It's not in the parts manual except for the drum unit as a whole. I have looked at the drums unit and it comes apart rather easily. If I had the parts I could save some money as most of there machines are well out of warranty. Thanks in advance for any help
  • habik
    • 2013
    Re: TA 3500i 4500i 5500i drum and cleaning blades
    Not that I know of.
    Only charge rollers due to using new coating to prevent bubbling up.
    Sent from portable device using fast cheapset!
    Firmwares HERE
    • Samanator
      • Sep 2017
      • 575
      Well hell, just did a search and found this website:
      Taskalfa 4500i, Taskalfa 4500i Suppliers and Manufacturers at Alibaba.com
      They have drums and blades but the cost of the drum is almost the same a new drum unit. Then tack on the blade and shipping and I might as well get the drum unit. Even better is the maintenance kit.
      Oh well. Now I know.
      If you guys can find better, please let me know.
        • 22999
        I've see only a few aftermarket photoconductors for the FalconI/II, and the results were typically disappointing. Kyocera has a lock on their photoconductor market. =^..^=
