CS 306ci No cyan listed on status page
  • Old-Tech
    • Aug 2016
    • 24
    [Electrical] CS 306ci No cyan listed on status page
    Hi all.
    I'm having an issue with CS 306ci cyan toner not showing up on the status report or in the Command Center. Updated the firmware and tried a new cartridge. Tried a new developer unit and REID board and same thing. Any help would be greatly appreciated. Thanks in advance.
    • 23009
    Re: CS 306ci No cyan listed on status page
    OEM toner?
    • Old-Tech
      • Aug 2016
      • 24
      Yes OEM toner, tried 2 of them and still didn't work
      • brancas
        • Jul 2009
        • 80
        Check if the drum unit is turning as it should. It may where the drum is connecting to.
        • JR2ALTA
          • Feb 2010
          • 2033
          I had one produce zero color. Extremely bizarre. 906 fixed it. I just backed away slowly..
          • Old-Tech
            • Aug 2016
            • 24
            Thanks, the drum is turning. It prints blue perfectly it just doesn't show up in the reports
            • Old-Tech
              • Aug 2016
              • 24
              Thanks, I tried 906 but it didn't help either. I wish I could back away too lol
              • blsquires
                • Nov 2008
                • 342
                this worked on the old color machines.turn off machine ,remove all toners then turn on machine, when its ready to print turn off again then put all toners back in and see if they all register.
                • Geo
                  • 662
                  If all else fails and I only suggest this as a last resort the nuclear option U021. This, in one case with a new 3052ci worked for me. Just remember this resets all values ( DV ,DK etc ) and counts (usage ) to default. Be sure to print out the maintenance report before doing U021.
                  Good luck...
                  • Kyo fan
                    • Dec 2013
                    • 368
                    Push the pin of the Cyan DV unit in. If it doesn't help, it could be broken on the inside, in which case you need another DV.
                    • Old-Tech
                      • Aug 2016
                      • 24
                      Thanks, I tried that and same thing. The Cyan didn't show up on the reports
                      • Old-Tech
                        • Aug 2016
                        • 24
                        Thanks, it is a brand new developer unit, I checked that and is working fine.
                        • Old-Tech
                          • Aug 2016
                          • 24
                          Good luck...
                          Thanks, I really hate to do this but it may come down to this
                          • Old-Tech
                            • Aug 2016
                            • 24
                            Thanks, that was my first hope and it didn't help either...
                            • RobertOB
                              • Dec 2018
                              • 26
                              It could be that the read sensor in the hopper assembly is messed up, have you checked it? And since it's such an odd issue have you spoke with your local Kyo rep? They see all the weird stuff all the time and may be able to offer some insight.
