4501i
  • yakyitz
    • 234
    [CQ] 4501i
  • Scott
    • 185
    Re: 4501i
    DRUM??
      • 22703
      Re: 4501i
      If that interval is 37.5mm and it's LEF, I'm going with primary charge unit. =^..^=
      • Scottb
        • Apr 2013
        • 301
        Re: 4501i
        fluorescent lights directly above the copier will cause similar issues with a sky shot. I would run a test image instead in service mode u89
        • brancas
          • Jul 2009
          • 76
          Re: 4501i
          I would do an internal test print.
          • yakyitz
            • 234
            • craigster
              • Apr 2016
              • 200
              Re: 4501i
              If you remove charge roller you will probably get a error code
              • yakyitz
                • 234
                • masterchill
                  • Jul 2005
                  • 100
                  Re: 4501i
                  Looks like its only black doing it? You can just swap the charge around and see if the problem follows.
                  • yakyitz
                    • 234
                    • yakyitz
                      • 234
                      Re: 4501i
                      Replaced the transfer belt and all is good. Thanks all.
