Fuser Troubles
  • yormets
    • May 2009
    • 336
    Fuser Troubles
    This fuser is leaving streaks and jamming occasionally. Can it be raired reasonably or should you just change out the unit. Anyone have a used 302L693021 that can be purchased. $459.00 was the best I could find for a new unit.
  • yormets
    • May 2009
    • 336
    Re: Fuser Troubles
    It's been that kind of day. It is a Copystar C3050I machine.
    • patrickjlc
      • Feb 2015
      • 225
      Re: Fuser Troubles
      You could order new rollers and clean up the fingers, and presto, a new fuser.
      Sent from my SM-G930V using Tapatalk
        Re: Fuser Troubles
        i would NEVER rebuild a fuser without replacing thermistors..thermostats and bearings also
        • patrickjlc
          • Feb 2015
          • 225
          Re: Fuser Troubles
          I get your point, but on my experience i get close to 100k prints from just replacing the fuser and pressure roller. Very seldom do I get a bearing failure. Might be because I don't charge for replacements parts, but for copies made, so try to save on costs on my end.....
          For people that get charged, I do use all new stuff.
          • RobertOB
            • Dec 2018
            • 26
            Re: Fuser Troubles
            Just order the maintenance kit, and the machine will run long enough to recoup the cost from the copies made.
            It's less work for you, and the customer will thank you.
            The other option is endlessly tearing apart and rebuilding the fuser as each part fails in time. That sucker is good for about 300k copies on the maintenance kit, if you can't make your cost back on that many pages then maybe you have other issues you need to look at.
              • 23006
              Re: Fuser Troubles
              Just to warn you, these are not the simplest fusers to get re-assembled once you've gotten them apart.
              When I scrap out a used fuser unit I try not to break or cut anything, so that I'm learning a useful task: how to properly disassemble the unit. This one is not easy.
              Buy the assembly. Once you buy the parts, you'll have to throw the labor in for free. =^..^=
