noise in fuser
  • Grumpo
    • Aug 2011
    • 7
    [Misc] noise in fuser
    Has anyone had any problems with the new 2 series machines developing a whining or squeaking noise in the fuser units, I have had to replace several recently and just replaced one that lasted 20 days and only 5k on it, I've checked the tech bulletins, only found one for exit unit noise, nothing for fuser noise, at this rate it's going to get expensive, any help would be appreciated
  • LNorris
    • Sep 2008
    • 645
    Re: noise in fuser
    if they are new, they are under warranty. we have had the 02 series make noises and thumping. replaced under warranty with no issues.
    • itchyfinger@att.net
      • Oct 2017
      • 77
      Re: noise in fuser
      It can be hard to tell if the fuser or the exit assm is the problem. We have replaced both in units only to have the noise return. Finally I just started to oil every shaft, bushing and idler gear in exit units and found the noise dose not return. but check your warranty on these units, we have claimed it on all fusers and exit units and have gotten the warranty
        • 23009
        Re: noise in fuser
        The squeaks that I have cornered have been in the exit unit, lower idler roller shaft. After over an hour of running every motor I could, as I was writing up there came a very small squeak, squeak, squeak, when idling. Customer described as horrible noise. They also insisted that the machine had been completely silent when idling up until recently, which I know is not true. It is not in silent mode. It only goes to prove that you can believe less than half of the observations provided by the enduser. =^..^=
        • JR2ALTA
          • Feb 2010
          • 2033
          Re: noise in fuser
          Change to silent mode at setup.
          • Geo
            • 662
            Re: noise in fuser
            An end user exaggerating...surly you jest.
            Cheers...
