KM5050 random faint gray line
  • copyaction
    • Oct 2007
    • 991
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: KM5050 random faint gray line
    Why not try dev unit?
      • 23010
      If these are copies, I would suspect that there is some lint on the optical mirrors or slit glass. The movement of the scanner can make dust bunnies move around. Also a dry scanner rail can cause a mirror assembly to tip slightly, presenting the dust bunny at just the right angle.
      The image content looks like internal reports, but you could very easily use internal reports to scan off of the glass or through the document feeder. =^..^=
      • copyaction
        • Oct 2007
        • 991
        I have ordered a developer unit and will try it tomorrow
        It does this on internal prints as well as copies
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1901
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • copyaction
            • Oct 2007
            • 991
            • tmaged
              • Oct 2008
              • 1901
              Hope that helps !
              -Tony
              www.dtios.com
              • JR2ALTA
                • Feb 2010
                • 2033
                Good info but all of that's been replaced.
                • copyaction
                  • Oct 2007
                  • 991
                  Yes they were both replaced together right from the maintenance kit (and yes it was doing it before they were replaced)
                  • daveh12
                    • Jul 2012
                    • 157
                    There is a drum blade that sits in front of the drum unit, its comes as part of the maintenance kit, it can become stuffed with paper dust and residual toner. has this been replaced or cleaned out?
                    • copyaction
                      • Oct 2007
                      • 991
                      No it has not.
                      How is that removed, through the front or from the left side?
                      I am going back with a new developer unit today so I can look at that part as well.
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        I think he's referring to the dust catch that snaps in. They're usually red in color. That whole area/cavity should be vacuumed out.
                        • copyaction
                          • Oct 2007
                          • 991
                          Replaced developer unit and cleaned dust collector still have line.
                          Is it possible for laser to cause this?
                            • 23010
                            Laser? Unlikely.
                            I think I would very closely examine the area around the drum for fibers dangling onto the drum surface. I've found fibers stuck to the grid, statically attracted to the drum blade, or stuck to the upper developer seal ... really anywhere within reach of the drum. These fibers can be very very fine, and nearly impossible to see.
                            • JR2ALTA
                              • Feb 2010
                              • 2033
                              5050 paper path is simple as they come. With a clean machine and new OEM parts and supplies there cannot be this defect. Are you on site or one of your techs? Something doesn't add up.
                              Maybe the paper has defects from factory?
