356ci new machine, Magenta everywhere!
  • mntech
    • Aug 2010
    • 250
    [CQ] 356ci new machine, Magenta everywhere!
    Hey all,
    I have a new 356ci that has less than 200 on the meter, machine ran fine during testing and after delivery, but a week or so later, customer calls about magenta on the whole page. I swapped drums, no change, inspected dev, contact plates, springs for transfer belt. At first I was thinking high voltage board, but then I covered part of the laser window with paper and the area that is covered is not affected, so now i'm leaning towards the LSU. Anyone else run into something like this on a brand new machine?
    Thanks,
    MNTECH
    for some reason I cannot upload these 2 pictures, so I will post links. The 2nd picture is with the laser glass partially covered.
  • itchyfinger@att.net
    • Oct 2017
    • 77
    Re: 356ci new machine, Magenta everywhere!
    any codes? maybe reseat magenta laser j connectors?
    • mntech
      • Aug 2010
      • 250
      There were codes for failed registration (can't remember exact code) but I assumed this was due to the high coverage of magenta.
      I'll double check connections at laser and engine.
        • 22698
        Looks like a laser issue to me.
        Reseating connectors might help but I doubt it.
        I like your diagnostic method. =^..^=
        • mntech
          • Aug 2010
          • 250
          Replacing the laser unit solved the problem.
          -mntech
