CS-5050 - crumpled/folded jam above fuser
  • Sudosed
    • Jan 2019
    • 6
    [Jamming] CS-5050 - crumpled/folded jam above fuser
  • darry1322
    • Oct 2010
    • 817
    Re: CS-5050 - crumpled/folded jam above fuser
    Possible broken exit guide. It's the black piece on the door that seats just above the fuser when you close the door.
    There is a small protrusion on each end of this guide . I replaced quite a few when one of these protrusions break off and cause that guide to seat crooked.
    • patrickjlc
      • Feb 2015
      • 225
      Past the fuser/heater? Could be the unit above the heater. Remove the top right plastic cover above the door, and see if there is a paper clip or something. That unit has two switches that get dirty and could cause jams.
      Sent from my SM-G930V using Tapatalk
      • ntbann
        • Jan 2012
        • 628
        What about the guide on the door where the fuser picker fingers come out of. It warps and breaks.
        • patrickjlc
          • Feb 2015
          • 225
          Could be this unit. The one on the left
          • darry1322
            • Oct 2010
            • 817
            This is the protrusion I was referring to in my earlier post. They tend to break off of one side causing the exit guides to seat with uneven pressure.
            Thanks patrickjlc for the picture.
            • Santander
              • May 2009
              • 768
              You have a bad exit assembly. Either one of the guide finger clusters on the unit has cracked and is slipping or you have an excessive buildup of toner and burned paper dust in the assembly. You could remove the exit assembly and thoroughly clean it, but the problem with eventually return. The long term fix is replacing the exit assembly.
                • 23006
                If you saved the scanner locking screw you can do a simple McGuyver that will outlast the rest of the machine:
                You might advise your customer that these parts are getting hard to get, so stop slamming the frickin' door.
                • Sudosed
                  • Jan 2019
                  • 6
                  Guys/Gals,
                  Thanks for your help!! Much appreciated!! I will see what I can find on Sunday and report back with pictures. Thank you!!
                  • Sudosed
                    • Jan 2019
                    • 6
                    Hi Guys/Gals,
                    Yall were right it was the exit assembly. Now I have a new problem.. Any idea where I can get one?
                      • 23006
                      You didn't look very closely at the photos, did you? =^..^=
                        i was just about to ask him the same thing!
                        • Sudosed
                          • Jan 2019
                          • 6
                          From what I can see that part is warped. I might be able to sand it down; but I'd rather replace it.
                            • 23006
                            It has nothing to do with warping. =^..^=
                              sounds like he just doesn't want to take advise.
