TA6551Ci with J 0509
  • taskalfa
    • Jun 2011
    • 97
    Hi all, just want to see if anyone has come across this jam code 0509 from the mpt, basically what happens is the mpt lifts as if its about to feed paper and then comes up with 0509 jam, so basically no rollers actually feed, u031 doesnt show up with any senors active, we have gone by the manual and have tried complete mpt assy, conveying door and pwb feed 1 and 2, so the only thing left is the engine pcb as per service manual. Copier has current firmware and 1 mil prints
    • 22973
    Re: TA6551Ci with J 0509
    You might check the modular connectors where the door mates. Specifically check the harness connectors that fit into the back of the modular connectors.
    I've seen cases where the harness just barely reached the other connector at the other end. So even touching the harness can disconnect the connector at the back of the modular connector. I re-routed the harness around a few looms to gain a little length.
    • taskalfa
      • Jun 2011
      • 97
      Hi guys, just updating, so far we have replaced pwb 1 and 2, engine , main, LV power supply, loom, connector, complete conveying assy, still getting this issue, we have escalated this problem with Kyo and see what they come back with. I read earlier that some techs had issues with newly released firmware ver 7 causing some weird issues ?. Again any thoughts appreciated
