taskalfa 2552
  • tommygun
    • May 2010
    • 21
    taskalfa 2552
    hey guys, quick Q, had the new guy replace the black drum in a 2552, but they didnt turn the machine off, so i had to go out there with a new one again to reset the drum refresh count, now the 1st new one has a count of 200K on it, is that count stuck to the drum now or is it just the one machine that will always think it has 200k?
    cheers
    • 23006
    Re: taskalfa 2552
    It should be written to the drum EEPROM, so yes, it is 200K to any machine it resides in.
    • copier tech
      • 8142
      Re: taskalfa 2552
      cheers
      Did he/you run the below after replacing the first drum?
      Please perform the below settings after "Ready" is displayed.
      1. Drum unit initial setting (Execute maintenance mode U119): Execute (High-end models only)
      2. Developer bias adjustment (Execute maintenance mode U140): AC Calib/Calibration (High end model
      only)
      3. ID correction operation setting (Execute maintenance mode U464): Calib
      4. Primary transfer unit initial setting (Execute the maintenance mode U469): Auto
      5. Adjusting the uneven density (maintenance mode U412): Normal Mode (High-end models only)
      6. ID correction operation setting (Execute maintenance mode U464): Calib (High-end models only)
      7. Adjusting the halftone automatically (Maintenance mode U410)
      • tommygun
        • May 2010
        • 21
        Re: taskalfa 2552
        the young guy said he did but who knows, i did when i put the second new one in its all good, i was afraid of the 1st drum being stuck at 200k, was hoping a different machine would reset it to zero.
        • Tonerkiller
          • Oct 2012
          • 668
          Re: taskalfa 2552
          The drum count resides in the machine. That new drum that you took out, you could use that in a machine that had a scratched drum or something like that. The issue is that if you put that drum that was already in a machine. In another machine. It will not reset the drum count. The count from the previous drum will still be in the machine. Yea I know, there is something not right about that, but that is the way it is. We had someone do it also.
          • tommygun
            • May 2010
            • 21
            Re: taskalfa 2552
            yeaha, got a new 2552 in today before run up put the 200k new drum, booted waited till it had finished its initial phase, still 200k on drum, not even that can help em fellas, make sure the new guy gets the memo and turns off the machine before swapping haha aaaaahhh
