TASKalfa 406ci toner smudge
  • kyove
    • Apr 2015
    • 62
    Hi Guys,
    I've just finish to clean a transfer belt of a TASKalfa 406ci.
    Machine has 23600 copies (23000 bw and 600 color) and 3 months of life.
    Problem was toner smudges (not every print) on paper.
    Transfer belt seems ok, i clean the "cleaning section" of transfer belt with vacuum.
    This is the only one machine I have under my maintenance.
    Usually they works well or have problems?
    Client prints with low coperture (average 3.7%)..
    What can I do? Maybe a defective machine?
    Thank you in advance,
    Kyove
    Re: TASKalfa 406ci toner smudge
    Originally posted by kyove
    Hi Guys, I've just finish to clean a transfer belt of a TASKalfa 406ci. Machine has 23600 copies (23000 bw and 600 color) and 3 months of life.
    Kyove
    try cleaning the WHOLE machine.. not just belt.
    check fuser for wear
    should post the counts on all parts to give us a better idea
    • JR2ALTA
      • Feb 2010
      • 2033
      I agree it's probably the belt. Kyocera had a bulletin and released seals around the drum and dev unit. But my fix for the comet drops was belt.
      But it doesnt matter they'll come back. The "3 digit". Kyocera models are costly little pigs.
      • Ropariva
        • 694
        We have replaced many belts under warranty in these. Keep sending the faulty ones back and they will have to improve them.
        • ChuckT
          • Jul 2020
          • 8
          Hi Guys,
          Kyove
          We have been having the same issue. We just keep a spare, and vacuum out the cleaning section, and reuse for the next machine.
          It isn't the best solution, but it keeps our customers happy. They/We don't mind the extra visits when it isn't out of our way.
            Hi Guys,
            Kyove
            does this have a cleaning blade or brush?
            if blade did you clean it and re-powder it?
            if brush, did you vac that?
            it sure would be nice if you could upload PDF's of the samples?
            what does the fuser look like?
            what toner OEM genuine or third party?
            do the use plain paper or thick?
            could it be residual gum from labels on the drums?
            where is the smudge located on the paper?
            so many questions so little info givne.
            Phil B. 'The Dentist'
              • 23010
              Is there an interval? Run the largest size, 50 pgs. =^..^=
              • tech07
                • Aug 2008
                • 410
                Install a new transfer belt. Had a few of these
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  You guys are addressing an old post. (Phil has addressed twice now, 17 months apart. hehe)
                    my bad bro... when i posted the latest i had just come in from dodging rain drops on the E130 and still didn't get all the hay bailed. still the south 40 to do.. expecting rain all fucking week till sunday.. it'll be asshole deep to an elephant by then again!
                    • jmaister
                      certified scrub
                      • Aug 2010
                      • 755
                      Fyi, this series have the following two problems.
                      1. drum marks, I dont know what you call them, but the drum gets these white marks on them overtime.
                      2. smudge, DEVELOPER. The same problem as TA250ci.
                      Image tranfer belt is very passive, it takes, it doesnt give, the smudge is from something "giving."
                      old kyocera problem.
                      Idling colour developers are not healthy developers.
