TaskAlfa 3252ci SQUEAKING
  • Konicatech
    • Feb 2016
    • 131
    Hi all
    i have a TaskAlfa 3242ci that is squeaking from somewhere round the back of the machine. For the life of me I cannot trace it! Has anyone come across any squeaks on this machine?
  • Ropariva
    • 652
    • Santander
      • May 2009
      • 768
      Re: TaskAlfa 3252ci SQUEAKING
      Originally posted by Konicatech
      Hi all
      I hate squeaks!!! Not on this unit, but had one on the previous model that drove me crazy, five calls for "squeaking". Except for the last call, every time I arrived the unit was not squeaking. Discovered that a clear plastic film disk covering one of the electrical clutches on the backside was causing the problem, you could see that it was lubricated to start with and adding a little grease to the entire surface of the clear plastic film resolved the issue. Crazy thing it is the film disk is not listed in the parts list so I would assume that it comes with the clutch and is supposed to protect the clutch from toner dusting. Found the offending clutch by placing a screwdriver tip to the end of each shaft with the handle to my ear [old car trick] to locate it. And as you would have it, there was only one person in the office that could hear the "squeak". Five hours labor for a dab of grease, go figure. Hope this helps.
      • JR2ALTA
        • Feb 2010
        • 2030
        This machine should have a Sim 30 to isolate. I've oiled up the feed drive unit before.
        • ntbann
          • Jan 2012
          • 627
          The fusers make noise and the bearings fall out on this series also.
          • sparkycivic
            • Apr 2017
            • 348
            our very first installed machine of this style engine (2552ci) had a nasty squeak from the rear of the device during the first two weeks, had to replace the drive pack assembly under warranty. I can't remember if it was noisy during any particular SIM drive, or idle anymore...
            • Konicatech
              • Feb 2016
              • 131
              Is that the paper feed drive assembly?
              • scottybbb
                • Dec 2010
                • 126
                I have always found that it is coming from the eject unit. Have had a few of the inner finishers squeak also.
                • sparkycivic
                  • Apr 2017
                  • 348
                  It was the main drum/dv drive assy.
                  The waste toner passages/auger are attatched to the front of this drive assy, and a new drive needs the old waste section moved onto it.
                  It's actually surprisingly elegant to swap, once you've handled one... especially compared to say, the dv drive in a 3051 or 250ci!
                    • 22999
                    I've only had a few of this series squeak and it was always the exit section idlers and bushings.
                    Let us know what you discover. =^..^=
