KM3050 Toner Sticking
  • lanierboy
    • 149
    Hello Everyone
    I Have a KM3050 where the toner keeps sticking to the upper fuser roller.
    we have fitted maintenance kits plus fuser plate/connector mod and tried lowering and increasing temp. after 2 weeks problem comes back.
    any ideas???
    cheers
  • 10871087
    • Jan 2005
    • 1062
    Do they run a lot of thick stock or 11x17? I have seen this cause problems on KM-2550 machines in the past (different fuser).
    • guru
      • Aug 2006
      • 18
      It is OEM toner? if not good luck ..
      not outsourced yet ...
        • 23009
        Are the fan filters clean, and all fans functional? And I would avoid aftermarket toner. =^..^=
        • lanierboy
          • 149
          update
          sorry for the delay in reply.
          use is standard copy paper and its genuine toner.
          am seeing machine tommorow and will check fans and filters.
          cheers
          • termacadon
            IT goofball
            • Oct 2008
            • 66
            Could it not possibly be laser intensity?
            I mean, if you have a strong laser its gonna create more charge for density, which means too high/low fuser temperature which could lead to the problem he is having now?
            My 2c
