8002 fuser not resetting.
  • djs9164
    • Mar 2018
    • 79
    I just replaced a fusing unit in an 8002i and the counter did not reset. The new serial number registered but the old count remained. U 167 would not allow me reset, all choices were greyed out except correction value. Previous unit had 914k on it, perhaps it was too high? Any thoughts. Firmware is current.
    Sent from my XT1635-01 using Tapatalk
  • Ropariva
    • 671
      • 23007
      Re: 8002 fuser not resetting.
      Is it the right model/right voltage fuser? It's not the first time that's happened. =^..^=
      • bush_tech
        • Jul 2018
        • 50
        If you don't turn these machines off before replacing units the old count can get written to the new unit.
        I've noticed this with drums and devs anyway.
        • Thayer
          • Dec 2017
          • 107
          I believe that, you can NOT reset fuser. It is part of Maintenance kit. The whole maint. kit would need to be reset.
          There is No maint C on this machine.
          • sparkycivic
            • Apr 2017
            • 348
            One should never swap EEPROM-equipped items while machine power is on, counts and/or serials will be messed up. It's so tempting when no tools are needed, especially when troubleshooting!
            • GeneOR95
              • Feb 2018
              • 161
