KM 3060 with error C6000
  • Mukasa
    • May 2015
    • 178
    Hi Guys ,
    I can't go to service mode after replacing the HDD , how can i reset this error C6000 , i checked the fuser is fine.
    Godfrey
  • Mukasa
    • May 2015
    • 178
    Re: KM 3060 with error C6000
    Originally posted by Apkareno
    try 10871087 or 30363036
    Thanks, i managed to reset the fuser and HDD format but still the error C6000 come back.
    I suspect the Power supply now what do you suspect to be the problem.
    Godfrey
      • 23008
      So you aren't going to check any of the fuser components?
      • zoraldinho
        teacher-guide-expert-guru
        • Mar 2008
        • 5013
        Originally posted by Mukasa
        Hi Guys ,
        Godfrey
        How did you check that the fuser is ok?
        • Mukasa
          • May 2015
          • 178
          i checked the Fuser lamps ,the thermostats with a digtal meter they were all ok .
          For the Thermistor at least the fuser has to warm up a bit , but the fuser is very cold.
          Godfrey
          • Mukasa
            • May 2015
            • 178
            Godfrey
            hello Apkareno ,
            all the fuser components are good , when i cable socket for the fuser i measured 220 volts mains but putting the fuser cable in its socket the 220 VOLTS disappears and it measures Zero volts.
            What can cause the 220 voltage drop?
            Godfrey
              sure as rain you Dismissed BlackCat's suggestions...
              you mentioned checking the LAMPS...
              what can pull down power?
              hmmm a SHORT ... ?
              sure slap another LVPS in it and when THAT doesn't fix it.. where do you go?
              how do you know the thermistor or thermostat in the fuser isn't bad... those two items tell the fuser lamps to turn ON and HOW much power to give to the lamps!
              how do you check them? hmmm resistance? hold the stat in your sweaty palm as you take the reading.. you will resistance change
                • 23008
                Isn't it interesting when the poster lists all the reasons why it couldn't be ... but won't try what you suggest. It doesn't bother me. They may get there eventually ... or not. =^..^=
                  BC.. I know this is one of your pet peeves also..
                  We have been around doing this when MOST were still attached to moms teet..
                  Go figure..
                  These are the type that "go on the list" for me...
                  Well 'maybe' he will reflect and in the future take advise from others like us..
                  But I'm done.
