Pin-out for DF-790
  • venluckey
    • 36
    [Electrical] Pin-out for DF-790
    Does anyone know the Pin-out of the DF-790 FN? What I need to do is be able to hook up the bracket wiring harness without a finisher. Essentially cheat the Finisher.
    I see the wire harness has 7 small wires and 4 main large wires, with one large wire being Green (on the one i have).
    I see the machine connector on the wire harness has the following slots with wires:
    1-7 on top row have no wires
    8-Grey thick wire
    9-Thick Green wire
    10 empty
    1-7 on bottom row are small grey wires
    8-9 are Thick grey wires
    10-empty
    Any Ideas?
    Thanks,
    Venluckey
  • craigster
    • Apr 2016
    • 200
    Re: Pin-out for DF-790
    That is going to be a tough one, If you had the attachment for the 790b.
    you could run machine without finisher on it.
    • wragsdale
      • Jul 2014
      • 188
      • wragsdale
        • Jul 2014
        • 188
        I should have included this one as well. Hope it helps.
