Cassette rollers for Kyocera
  • Hansoon
    • Sep 2007
    • 3383
    Guys is there any list around to what models the following rollers are fitting?
    Pick Up Roller # 2BJ06010
    Feed Roller #2AR07220
    Separation roller # 2AR07230
    I would need them for the KM-2050/3050/4050, are these OK for that purpose?
    Hans
    • 23007
    Re: Cassette rollers for Kyocera
    I can tell you for sure that those rollers won't work on the FalconIII. The pickup is larger and ribbed. The feed and separation are both larger. =^..^=
    • Hansoon
      • Sep 2007
      • 3383
      Thanks Cat, stupid question from a KonicaMinola guy: Whats FalconIII?
      Hans
        • 23007
        CS-3050, CS-4050, CS-5050. KM-3050, KM-4050, KM-5050, IKN-5050 and any re-badges that I don't know about.
        • Hansoon
          • Sep 2007
          • 3383
          But those are not the same rollers as the KM-2050/3050/4050 uses isn't it?
          Hans
          • Hose1cook
            Defective Technician
            • Jun 2008
            • 80
            Right out of the 3050/4050/5050 Parts Manual, they will fit all the machines you mentioned, along with Falcon 1,2,(3) & 4 and the 1620,1650,2020,2050 ,2550 series.
            2AR07220 PULLEY,PAPER FEED
            2AR07230 PULLEY,SEPARATION
            2BJ06010 PULLEY FEED A
            • JR2ALTA
              • Feb 2010
              • 2033
              Horsecock is right. Add the 420i,520i to that list.
              • wragsdale
                • Jul 2014
                • 188
                Originally posted by JR2ALTA
                ... is right.
                • ntbann
                  • Jan 2012
                  • 628
                  How do you get horsecock out of Hose1cook?
                  • Vincent128
                    • Sep 2015
                    • 349
                    by fondling ?
                    • Hose1cook
                      • Jun 2008
                      • 80
                      I've been called a dick before but that's rather extreme, and nasty.
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        Meant to be immature, not mean-spirited. I'm sorry.
                        When I first glanced at your handle and that's what I thought it said, I chuckled about it. Should've kept it to myself.
                        But I accept if you report me and maybe Admin can just clean up the thread for us.
                        • Hose1cook
                          • Jun 2008
                          • 80
                          Apology accepted.
                          • ntbann
                            • Jan 2012
                            • 628
                            No need to report. I thought it was funny?
                            • Geo
                              • 662
                              Uhh..Could be a compliment...
