3510i DP772 CQ issue
  • copycart
    • May 2009
    • 97
    [CQ] 3510i DP772 CQ issue
    I have a 3510i with 206k on the machine and 980K on the scanner. I'm getting background when I scan a document to the desktop and when I make copies through the DF. I have cleaned the optics, slit glass and exp. glass. I also clean the lens array in the DP772. I'm still not having any success. The shading is set to default which is 0 in Service program 63. Any ideas will help. I'm sending a copy of copies, I hope they show my problem.
  • copiertec
    • Jan 2016
    • 2201
    Re: 3510i DP772 CQ issue
    Have you checked the hinge assembly right and left?
    • Geo
      • 662
      Have you tried adjusting the default???
