3252ci Scanning problem
  • Rlcdrew
    • Dec 2018
    • 21
    [Misc] 3252ci Scanning problem
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1883
    Re: 3252ci Scanning problem
    Select original size statement-r. You're telling it what to scan rather than letting the machine figure it out. I usually do a program key or shortcut.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23007
      Like Tony says, just select the original size that you want scanned. IMHO it's about the same amount of trouble as laying the paper behind it.
      The machine is trying to match paper size, and clearly you won't have any ISO B8 paper loaded. Even if you did, it's too short to feed through this (or almost any MFP). =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        Don't must current machine have ID/Card copy feature in copy settings you can shortcut as well.
        • Rlcdrew
          • Dec 2018
          • 21
