Hey all,
I've got an interesting fault I'd love some ideas on
The machine in question is a TaskAlfa 3252ci, its displaying a C7901 error (Drum unit K eeprom).
I think this is the first code it arrives at because there seems to be quite a major issue.
What's strange is if you go through maintenance mode there is no serial number/count information for all units (fuser,belt,drum,dev)
So basically it's as though they are not installed.
You can simulate this exact fault on a functioning machine very easily by unplugging one of the cables that connect the feed image pwb with engine pwb.
Things that have been tried: Feed image pwb, engine pwb and the loom between the two, forced firmware (completes with no error), 21+906
Both these boards loom and all the units work in another machine, and display their serial numbers/counts etc.
Any ideas where to next?
