Kyocera M6525idn Color copies and prints are disable
  • bryant28282000
    • Jul 2012
    • 145
    I got three Kyocera C M6526 and I cant get these machines to print or copy in Color. I format the SD card and choose default to factory in the service mode, I change everything in common settings to color, I can take the color toners out and it wont ask for color and will print in b/w. I have done everything and cant figureout why do these copiers print and copy only in color. I ungraded the firmware and tried through the drivers. I dont understand how the last user disable color
    • 22999
    Re: Kyocera M6525idn Color copies and prints are disable
    Since you say (3) times that it prints in monochrome and (1) time that it prints in color, should we assume that the prints are monochrome (or color)?
    Is it a M6526 or a M6525?
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1869
      Check system settings & make sure it's not set to print B&W when it's out of color toner. It never lets you know it's out of a color when it's turned on.
      This is a great idea by Kyocera but very poorly executed.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Xer0615
        • Jan 2019
        • 48
        Pardon my potential ignorance, but in these desktop models, are not the "idn" units B/W only? if it were color capable, would it not be "cidn"?
        • wragsdale
          • Jul 2014
          • 188
          There is no M6525idn, M6525cidn, M6526idn. Only a M6526cidn. I think, judging by the fact that he/she removed color cartridges, it's almost certainly a M6526cidn which is specifically a color engine and has no monochrome counterpart.
