5550ci takes 5-mins to make 1 copy ?
  • Xer0615
    • Jan 2019
    • 48
    #16
    Re: 5550ci takes 5-mins to make 1 copy ?
    Originally posted by Scott
    Silent mode
    silent mode can cause delays but not totaling to minutes to make a single copy, if I'm not mistaken-- unless other issues are involved.
    In my limited experience, the network is often the issue-- but given that this happens with copies and not just print jobs, It is safe to assume that's not a factor. I believe I've also seen hard drive and memory issues cause the problem. In one instance I believe we had to replace the hard drive, in another instance we'd simply run a simulation that, I forget what exactly, but effected the memory.
    • djs9164
      • Mar 2018
      • 79
      #17
      Check in adjustments and see if someone enabled silent mode.
      Sent from my XT1635-01 using Tapatalk
      • CCS
        • 266
        #18
        I ended up swapping the fuser and fuser IH unit, problem solved, thanks.
        • Ropariva
          • 703
          #19
          Appreciate the feedback. Did you find any foreign material in/on the non-contact thermistor?
          • CCS
            • 266
            #20
            no
            • GeneOR95
              • Feb 2018
              • 161
              #21
              If the sleep level is set to Energy Saver on these models it can cause significant delays when waking up. Check the setting and set to Quick Recovery and recheck.
              • Alexsiskm
                • Sep 2018
                • 11
                #22
                perform data sanitalization, it will definetly help for delays.
