5550ci takes 5-mins to make 1 copy ?
  • CCS
    • 266
    Intermittent, sometimes machine will sit and wait, blink for 5 minutes or so before it will make a single copy,
    pwr off/on and is alright for a short time, then goes right back to same waiting game,
    any suggestions?
  • copier tech
    • 8220
    Re: 5550ci takes 5-mins to make 1 copy ?
    any suggestions?
    Update the driver & firmware?
    • guitar9199
      • Sep 2016
      • 1100
      I had a Ricoh/Savin that was doing something similar. "Decurl" was turned on. Once I turned that off, first copy out time was about 4-5 seconds.
      • Ropariva
        • 703
        • guitar9199
          • Sep 2016
          • 1100
          Good tip.
          • CCS
            • 266
            Their IT dept. updated the print drivers and now it seems to print faster, but walk up copy extended times are still an issue, I updated f/w.
            Now that I think of it, the machine had a C6200 fuser code ( which is thermistor #2 not reaching temp in allotted time) a few days ago that the customer cleared with a pwr off/on and it has not come back, but that may well be causing my issue...
            I will try a fuser from the shop
              • 23010
              What media types are your trays set to? =^..^=
              • JR2ALTA
                • Feb 2010
                • 2033
                Slow printing ALWAYS needs to be tested with a local driver. I don't know all your details but if it's faster local vs server then that's their problem.
                If there's still a lingering problem with copying. Check "Quiet Mode" in System Menu. Off is faster On is slower (out of sleep) but with all the noises these machines make I prefer it On..
                • tmaged
                  Owner/Service Manager
                  • Oct 2008
                  • 1901
                  As mentioned check quiet mode. I've also had a couple machines do that when copying. That eliminates any driver issue. Mine needed the HDD's replaced.
                  Hope that helps !
                  -Tony
                  www.dtios.com
                  Become a fan on Facebook
                  • craigster
                    • Apr 2016
                    • 201
                    i would say HDD, any errors on the event page?
                    • CCS
                      • 266
                      Plain
                      • CCS
                        • 266
                        C6200 4ea
                        C8800 1ea
                        Cf14d 1ea
                        Cf234 1ea
                        Cf245 2ea
                        • Ropariva
                          • 703
                          C6200 indicates fuser thermistor. Have u swapped out the fuser yet?
                          • bush_tech
                            • Jul 2018
                            • 51
                            This has always been a fuser issue for me
                            Especially if you see jams 01xx in the log
                            • Scott
                              • 198
                              Silent mode
