CS 5501
  • Scottb
    • Apr 2013
    • 306
    CS 5501
    This guy has 3+ million copies, and has developed a light edge on both prints and copies. The first tech replaced the DV and Drum with both new units, and the transfer assy with an known good one. I removed the laser and lifted the top and cleaned the mirrors, ran all the adjustments...other than the toner recurve because it wouldnt read it correctly with a light edge
    • 23006
    Re: CS 5501
    The laser was my first choice. At 3M it will have dusted significantly into the laser.
    What does the latent image look like on the drum? =^..^=
    • kyogenius
      • Jul 2012
      • 136
      Re: CS 5501
      i do agree with Blackcatt ,its more on the laser than anything else.
      failure is not an option !
      • JR2ALTA
        • Feb 2010
        • 2033
        Re: CS 5501
        Did you just clean the top laser mirrors? You need to flip it over remove the 4 polgyon motors and clean those 5 sided mirrors.
        As it spins it hits dirty air and develops a smudge mark on an edge of each face.
          • 23006
          Re: CS 5501
          I don't know if this will work from the phone... :
          I guess it does. =^..^=
          • Scottb
            • Apr 2013
            • 306
            Re: CS 5501
            I took a spare laser (from a donor machine) with me and swapped it out, with the intention of bringing the old one back and cleaning the poly mirrors...but it fell off the copier and hit the concrete floor it appears to be in one piece but I doubt, that I would trust it as a back up.
            Copies are clean and crisp once again
            Thanks guys
