km 5050
  • Where is my screwdriver
    • Nov 2016
    • 16
    #16
    Re: km 5050
    Have you tried a U163 reset on this device. This is normally reserved for fuser errors but has reset other errors in the past.
    • everestphotocopy
      • Jun 2019
      • 8
      #17
      Re: km 5050
      ya tried u163 and u24 too. but nothing seems to work for me.
      • Santander
        • May 2009
        • 768
        #18
        Re: km 5050
        Since you say you tried 2 sided to one sided and it said not available, you have eliminated the print side. Since the machine is indicating that the function is not available, it does not recognize that it has a two sided DP. To me this would indicate a bad wiring harness or a defective main PCB.
        • Drewsup
          • May 2019
          • 9
          #19
          Re: km 5050
          can you do multiple sets of single sided originals using the DP?
          if a Kyo HD goes bad on older machines, it may not show an eror, but since the HD is used to replicate the sets, you get a "Cannot use this function" message
            • 22989
            #20
            Re: km 5050
            Falcon III's will show C0640 when the HDD fails. =^..^=
            • Drewsup
              • May 2019
              • 9
              #21
              Re: km 5050
              these were same tech era as 6030's, many a time you would go to one that appeared normal, but as soon as you selected multiple sets it say declare option unavailable. there are usually HDD errors in 904, but once machine is reset at power, everything looks normal again.
              • everestphotocopy
                • Jun 2019
                • 8
                #22
                Re: km 5050
                i have 2 5050 machines and both show the same message. I tried changing the PWB too but does not work in both the machines.
                • copydocinc
                  • Mar 2015
                  • 263
                  #23
                  Re: km 5050
                  I have 2 possibilities.
                  1. The duplexer connector is unplugged or loose.
                  2. Have you actually put a paper in the doc feeder? or trying to do this on the glass won't work
                  with a 2 to 2 setting.
