3252ci Wrong Paper size
  • Rlcdrew
    • Dec 2018
    • 21
    I've been dealing with a 3252ci that when doing Ledger size prints from Adobe reader they will sometimes print on Letter size paper and it cuts off most of the print. Its happened on 3 different PC's. Even have a 6052ci thats doing the same thing but instead of Ledger size its doing Letter size prints onto Legal paper. Each machine has the cassettes set to a specific paper size so its no longer auto detecting the paper. Anyone have the same issues?
    • 23010
    Re: 3252ci Wrong Paper size
    Originally posted by Rlcdrew
    ... Each machine has the cassettes set to a specific paper size so its no longer auto detecting the paper. Anyone have the same issues?
    That's the first thing that I would change. Kyoceras Auto Paper Detect accurately when set to Auto Inch or Auto Metric (for metric users). They will not print faxes to trays set to a specific size, even when it's exactly the size needed. Be sure that the trays are accurately auto-detecting paper size. =^..^=
    • Rlcdrew
      • Dec 2018
      • 21
      • Tonerkiller
        • Oct 2012
        • 669
        Auto/inch is the way to go.
        • Ropariva
          • 703
          • Rlcdrew
            • Dec 2018
            • 21
            • JVergin
              Service Tech / IT Rep
              • 216
              I had this issue with one customer on a 2552ci. They also said sometimes they'd do a standard print job, and it would choose to pull from the MP tray. Of course it was out of town and I couldn't reproduce any of the problems.
              - I set all paper trays to a fixed paper size instead of auto.
              - system menu -> Printer -> paper feed mode set to Fixed (Sometimes as "Auto" the copier will ignore commands from the computer to print from a specific tray)
              - I deleted the Kyocera printer and any Kyocera print driver from their computers and started fresh. They had 2 versions of the KX print driver installed, plus a KX XPS driver that windows probably installed automatically. Sometimes having multiple print driver versions can cause intermittent problems.
              - Educated them on "Page Setup" in some programs will override any print driver settings for that document. Make sure the page setup for the document isn't forcing the printer to pull from the MP tray, or some other tray.
              - Educated them that sometimes things don't happen as desired with ANY electronic equipment. If its something that happens once every couple months, it's probably not something to get too concerned about.
              Haven't heard back from them since!
              • Rlcdrew
                • Dec 2018
                • 21
                I think I will try these tomorrow at another site. Thank you!
